Downloading from a new Vista computer?
DeDe15
Post by DeDe15 »
Hi!
Have not been on here in forever and have to get back to getting things in order. This may be a question for Todd, but here goes.... My old computer is finally gone and I had to switch to a Vista computer. My original SCAL program is on my old XP system (former computer.) My Cricut Expression was running on the old system perfectly fine. If I download the new update/version onto the new computer, can I run the new version and more importantly, will it run correctly?
I think I may still have my original code to run the program - do you think this will work? Any experience with this would be helpful.... hope all of these machines talk to each other!!
Denise
NurseMel
Re: Downloading from a new Vista computer?
Post by NurseMel »
Hi Denise,
The SCAL download is the same version for both XP & Vista. I have Vista and run mine in compatability mode for XP as it used to crash a bit otherwise. Your code is good for two installs (I check with Todd before cos I wanted to put it on my desktop and laptop - one is Vista, one is XP).
Hope this helps,
Mel
DeDe15
Post by DeDe15 »
Thanks... but there's the question. I want this on my laptop, but will I need a new code to put it onto the new desktop, since the old one is gone? If I use the code again, then I won't be able to put it on the laptop? Think I'll try the download later or email Todd about how to handle.
Thanks!
Denise
wreed06
Post by wreed06 »
You should be able to use the same authorization code on different computers. If it doesn't work, just ask Todd for another one.
