Signpost
lottie
Signpost
Post by lottie »
I am after a simple little signpost shape - i.e. a square with a stick - if you follow me!!
pastda3
Re: Signpost
Post by pastda3 »
Well, he's one with a square and stick. But honestly, that could've been made very simply with the basic shapes in SCAL. I also made a couple of more styles for good measure. Hope they help. :)
sign_with_post_by_rs.svg
(5.8 KiB) Downloaded 144 times
Re: Signpost
Basic and GREAT job...I will use them too :)
lottie
Re: Signpost
Post by lottie »
Perfect - thanks - yes - thought I could make one but not sure how to attack that!!
pastda3
Re: Signpost
Post by pastda3 »
Lottie - maybe this will help. I did this in SCAL2. In the Basic Shapes Table you'll see the square. Select that and a square will appear on your mat. Click it again and you'll have another square. Click on one to make it active. You'll see a bunch of circles with arrows in them. The first thing you need to do to change the dimensions is to uncheck the "keep proportions" option. Then you can pull down and push in the single arrows in the circles to make the square longer and narrower to form your "post." You could also change the width and height size by changing the numbers in the "properties" box, but again make sure the "keep proportions" option is unchecked. Hope I didn't confuse you.
Carolien
Re: Signpost
Post by Carolien »
