Can someone make this pls
I am looking for this to cut out. I just cant do inscape, can someone pls help?
- the symbol
- FF7883435B2946F69C1ACFD5DDCE845A.jpg (16.11 KiB) Viewed 2924 times
Re: Can someone make this pls
Hope you can use this
- Ford F100 0912.svg
- (19.41 KiB) Downloaded 322 times
perfect, thankyou sooo much
Re: Can someone make this pls Help
She sounds like me. I just got this cricut expression .....sooooooooooo excited about what all it says it can do but no indepth instruction on how to do the things I want. I have a word pic that I learned you needed to place in Inkscape to convert to svg file so it can be used on Sure Cuts A Lot. I almost cried with frustration not knowing how to do it but I pushed enough buttons until it worked. Do not know what I did but it worked. The only problem is that the inside of the letters have flecs of garbage and when it cut, it cut those as well. Sooooooooo..........How do I clean up my picture so that it is clean and only cuts the outline of what I want. Would appreciate any help for this very green disappointed cricuter who got excited when she cut out a page of circles per her husband's wish and after several youtube videos was able to do so
If you post the image, I will look at it and tell you what u need to do. I can give you basic instructions, but there may be other steps you need to take and I would rather see it before I give ins.
Althea
Althea
