Can you mix carts and svg files together?
bkbea
Post by bkbea »
I am trying to figure out how to use the skull designs from PDDU with the curlz font in scal. Is this possible or do I need to convert the skull scut into a svg file first. If so, what are the easiest steps. (I do have inkscape). Thanks so much for any help.
kaesmom
Re: Can you mix carts and svg files together?
Post by kaesmom »
You can't use any of the cartridges in SCAL. You can only use SCUT or SVG files in SCAL. You'll need to find the skull as a dingbat and cut it that way.
wreed06
Post by wreed06 »
If you can make a graphic file, such as a jpg or gif from a single object in that cart, then you bring it into Inkscape and create an SVG from it.
bkbea
Post by bkbea »
wreed06 wrote:If you can make a graphic file, such as a jpg or gif from a single object in that cart, then you bring it into Inkscape and create an SVG from it.
How do I save the graphic? When I right click I don't get the normal menu that includes "save Picture as".
wreed06
Post by wreed06 »
No, you wouldn't be able to right click and paste it. You would have to capture it via print screen, or a utility tool that can capture objects for you (such as SnagIt - pricey at $50 but I love it and get a lot of good out of it.) Anyway, once you get the graphic, you can copy it into Inkscape and play with it there.
