I haven't cut this yet....let me know if there is a problem.
Beth
I Love You Sign
I Love You Sign
- iloveyou.svg
- (1.08 KiB) Downloaded 257 times
- iloveyou.jpg (22.65 KiB) Viewed 3870 times
Re: I Love You Sign
I don't think the down fingers will cut well. They will show as sort of triangles. Not really sure how'd you change the middle fingers. Maybe remove the "triangular-like" shapes all together in Inkscape and just draw the lines instead. I've uploaded the version without the middle fingers outline.
- iloveyou2.svg
- (2.62 KiB) Downloaded 134 times
Re: I Love You Sign
Thanks for your input. I have the down fingers so they don't cut out all the way... basically it would just make a cut mark to show the fingers......
One could use your version and add I love you on the inside of the palm.
Beth
Beth
Re: I Love You Sign
Thought I would put my two cents in...have included a version with the two fingers as a layered cut and the outline also
- iloveyou.svg
- (11.47 KiB) Downloaded 159 times
- iloveyou.png (10.15 KiB) Viewed 3789 times
Re: I Love You Sign
Curious - did you adjust the down fingers in Inkscape first? When I looked at the original in Inkscape and SCAL it had an odd shape in each down finger. Yours looks great!
Re: I Love You Sign
I did a PrintScreen, saved as jpg, opened in Inkscape, traced and then I made the outline for the fingers smaller using the Tweak Object (3rd icon down). Then Break apart.
Re: I Love You Sign
AnointedHands wrote:Thought I would put my two cents in...have included a version with the two fingers as a layered cut and the outline also
Looks great thanks!
Beth
Re: I Love You Sign
wreed06 wrote:Curious - did you adjust the down fingers in Inkscape first? When I looked at the original in Inkscape and SCAL it had an odd shape in each down finger. Yours looks great!
It looks fine in SCAL on my computer.
Sorry it didn't work for you.
Beth
