- small ornament.jpg (49.97 KiB) Viewed 7485 times
swirly ornament
swirly ornament
I saw an ornament like this in the Menard's ad. Here is my version of it.
- ornament2.svg
- (20.08 KiB) Downloaded 865 times
Toaster
SCAL 2 , SCAL 3, Windows 10
Re: swirly ornament
GORGEOUS!
Re: swirly ornament
Beautiful!
Re: swirly ornament
That is fab! I tried to do something similar but got a weird error in SCAL. I failed to check but did you do it in Inkscape?
Re: swirly ornament
I did work on it in Inkscape. Do you have SCAL1? I found that some files don't always open right from one to the other. I opened it in SCAL2 with no problems but when I opened it in SCAL1 some of the lines had moved alittle and the selection box was much larger than it should have been. I went back to Inkscape and tried to change it but it still came out that way in SCAL1. I wish I could help.
I read your post again. I'm now thinking my answer is not what you asked.
2nd Edit: With help from Grammy Krausse I was able to fix the file so it should be fine in SCAL1. This is a SCAL1 file.
- ornament1.svg
- (20.94 KiB) Downloaded 140 times
Toaster
