Lrg Scallop Edged Square Card
A large scallop-edged square card:
Sure hope someone finds this useful. It was my first time creating an SVG file. First time uploading to share as well.
Cheers!
* SCUT file removed *
Cheers!
- 5x5 Scalloped Card 3.svg
- SVG file:
- (97.79 KiB) Downloaded 1716 times
Last edited by Carrie_Creates on Tue Jun 17, 2008 1:00 pm, edited 1 time in total.
Re: Lrg Scallop Edged Square Card
Carrie, thank you very much. As a card maker I am sure I will make use of these
SharonV
A Birth Certificate shows you were born.
A Death Certificate shows you died.
A Completed Scrapbook shows that you LIVED!!!!
http://scrapandstamp.wordpress.com/
Carry, I was sooooooooooo excited to see this file! I quickly downloaded it..thanks! When I cut it out it cut a line staight across several of the scallops cutting them off. Is this a problem on my end?
Thanks again,
Cynthia
Thanks again,
Cynthia
Here's a picture
- scallop.png (8.45 KiB) Viewed 9896 times
I loved the scallop edged card too. I also noticed in preview that there is a cut line under three scallops about the middle of the top. I don't know how to fix it in inkscape so I'll wait until someone who knows what they are doing to fix it and then I'm off to create with it. I've attached a pic of the preview mode.
Thanks for doing the design, I'm sure it will be perfect for me.
- Picture 2.png (9.27 KiB) Viewed 9883 times
I downloaded the SVG file and didn't have a problem with an extra line. Can't wait to use it! THANKS!
Can someone fix this...it cut the line out too....
Is it just the SCUT file that has the line problems? I'll admit, I used the SVG file when I cut mine.
Sorry for the problems. I really don't know how to fix a SCUT file.
I used the svg and it's fine ...couldnt use the other one.
I am also getting the cut line under the 3 scallops. If you open the svg file and ungroup, that segment is separate from the rest of the card. Does anyone know how to join them?
