How do you do this?
Grandma G
How do you do this?
Post by Grandma G »
Is there a tut on how to do this?
JaZver
Re: How do you do this?
Post by JaZver »
haven't heard of it before..
but wait i'll ask my sister about it..
i'll pm you..
If you are talking about the names in the smiles, the best way would be to use a program that has word art such as MS Word. Another option is Envelope distortion in Inkscape, but that distorts the letters quite a bit.
mjfitz
Post by mjfitz »
I would love to know how to do this also...I get the name in word art
probably created more work but saved it as a pdf and then converted to jpeg, brought into
inkscape and saved as svg to import to scal
does anyone have an svg for the mouth part, I am horrible at drawing shapes..thanks
mjfitz
Post by mjfitz »
nevermind..i found a half circle in clipart and saved as an svg
ProfessorLooney
Post by ProfessorLooney »
If you have inkscape this is rather simple,
Draw or get the smile face
Type a name
go to path, object to path
place where you want the smile to be inside the teeth section
ungroup
select a single letter
shift and select the smile at same time.
goto path, select diffirence
and then continue through the name.
mjfitz
Post by mjfitz »
Grandma G, Thaks for posting this pic,
I was determined to try this, it was a bit time consuming
but through many trials and erors I finally did it
here is my version
dascall pumpkin1.jpg (52.56 KiB) Viewed 3401 times
