The name Michael Lee ?
ChristyBaker
Post by ChristyBaker »
would someone do a svg of this name for me in some type of Cursive ?
also I have dl svg's and when I open them they try to open in acrobat and it says it does not support it . can you tell me how to fix it ?
thanks bunches !!!
talanhart
Re: The name Michael Lee ?
Post by talanhart »
ChristyBaker wrote:would someone do a svg of this name for me in some type of Cursive ?
thanks bunches !!!
I'm pretty sure Acrobat only opens PDF files. You might try opening the SVG files in INK and then saving them as PDF files.
ChristyBaker
I don't have ink . when i dl them it said they were svg ive only had this happen a few times . i dl them from some blogs .
i don't have michael lee as a svg
Save your file then right click on it.. look down the column and look for "Open With" then look for inkscape and open it with that.. you can also set it if you look further down the column and it should say always use this program for opening files of this type...
Butterfly
Post by Butterfly »
Michael Lee.png (37.89 KiB) Viewed 1902 times
Hope this is what you want,It is very easy to do in SCAL
Michaellee.svg
(52.79 KiB) Downloaded 114 times
Scrappin My Way Through
ChristyBaker
O thank You so much !!!!! I'm still learning and lordy it would prob take me a month to figure out how to do it my self lol
ChristyBaker
Sweetness4713 wrote:Save your file then right click on it.. look down the column and look for "Open With" then look for inkscape and open it with that.. you can also set it if you look further down the column and it should say always use this program for opening files of this type...
thank you I think some how i must have said open it with acrobat which i don't remember doing lol
