Face Off and Face It fonts
Share your favorite fonts to use in Sure Cuts A Lot
lindamac
Post by lindamac »
Just got to thinking after downloading these two fonts. Using a gel pen with the Cir-Kits holder we can now add faces to our projects using our Cricuts!!!! I bought a bunch of mini gel pens from Staples and am in the process of cutting the ink cartridges down to the size of the Cri-Kits gel pen. I will designate one pen from the Cri-kits to use the other ink cartridges with. Just pry the top off the Cri-kits pen and insert your shortened cartridge, pop it back together and there you go! I was just going to drill out a bit of the tops of the Staples gel pens and glue a ball bearing in place but the pen housing is too big to fit in the Cri-Kit pen holder. I bet they did that on purpose!
firstcut
Re: Face Off and Face It fonts
Post by firstcut »
I tried this and I got double lines with the gel pens on these. I think they would work with sharpies, though, or you could fill in between the lines by hand.
