I'm stuck
I'm stuck
OK, this is probably really stupid, but I opened a scut file I made and saved, and I want to know what font I used but I don't see how to find out. I scrolled down the list of fonts and didn't recognize it. Shouldn't it tell me somewhere what I used?? I'm going to feel stupid when someone tells me how easy it is.
Re: I'm stuck
I thought there was a way to find out what font you used but I can't find it so I'd like to know too.
Toaster
SCAL 2 , SCAL 3, Windows 10
Re: I'm stuck
I don't know if it's different for earlier versions, but with 2.013 all you need to do is select the text and look at the text sub-window (in the Proporties window). This will only work if it hasn't been converted to outlines. HTH
Re: I'm stuck
Normally in SCAL2 if I use a font i really like I save it to my favorite fonts right in scal...
Re: I'm stuck
I'm on version 2.012. I looked at the downloads and 2.013 isn't available. Wasn't it taken down because it had problems?
Toaster
Re: I'm stuck
It was taken down but some of us managed to get it before they did. .. I have it and don't have any problems with it.
- Location: Central Valley,California - SCAL-1, SCAL-20.28, Ink.47, Vista
Re: I'm stuck
You can also open the file in question and select this project from the View pull down font menu and it will tell you the font used. I know it works for me all the time. Hope this helps
