crop
crop
I would love to see a cropping tool. so many times I have wished for one, or is there one and I just have not found it yet?
Scrappin My Way Through
Re: crop
Depending on the file, you can use Path/Intersection in much the same way that you would use a crop tool. Draw your box or other shape over the artwork and use Path/Intersection in SCAL 2.010 or newer. This will only work on single items, not artwork with grouped or welded pieces. HTH
Re: crop
If SCAL had the function to delete nodes, that would also do the job.
Re: crop
Thank You Heather I just now seen this.
I think scal does delete nodes.
Re: crop
Please tell me how to delete them. I have not been able to do it. I guess I want the fast way which is select a node and hit an icon to delete it.
Re: crop
I don't explain things very well, But here is the tutorial on deleting nodes in SCAL
http://svgcuts.com/blog/2010/06/08/sure ... -tutorial/
Re: crop
Just click on the node and use the backspace feature on your computer.. I explained in another post
Re: crop
Glad I posted here. Couldn't believe deleting nodes was so easy. After I read this I decided to check in Funtime (use for Gazelle cutter) and found out all I have to do is hit Delete...couldn't believe it. I have been thru hell and high water to delete nodes and all I had to do was hit the delete button...duhhhhh
