Baseball Cupcake Wrapper
Posted: Wed May 12, 2010 2:13 am
by gmapatty
Does anyone know where I can find a cupcake wrapper for baseball? And also does anyone know the dimensions of a cupcake wrapper (height and width, etc.)
Re: Baseball Cupcake Wrapper
Posted: Wed May 12, 2010 6:11 am
by mrs.c
I made this one, I hope you can use it. As for the size I really think it depends on the size of your cupcakes and the pan you use, I would do a test cut and then go from there. HTH!
Posted: Wed May 12, 2010 7:47 am
by gmapatty
Thank you , that would be perfect except that I have not made the plunge and pruchased SCAL2 yet. I am still getting used to SCAL. I would not be able to open your file, it has to be an svg for right now.
Thank you
Posted: Wed May 12, 2010 8:20 am
by mrs.c
Here is the svg version, it is a little different though, but I still hope you can use it!
Posted: Wed May 12, 2010 8:41 am
by wvcathy
This is really cute - you were so quick to respond to the request posted I am sure she will love it....
Good job
wvcathy
Posted: Wed May 12, 2010 5:11 pm
by gmapatty
Thank you for your help. When I open the file in Inkscape it is fine. But when I open in SCAL, it is separated and I cannot get it to go together. The baseball (only one) is separated. Any ideas??
Posted: Wed May 12, 2010 5:50 pm
by lkc
I think this should work...I ungrouped it and all the balls show up in scal...hope mrs c. doesn't mind.
bbac_mrsc.svg
(33.35 KiB) Downloaded 237 times
Posted: Wed May 12, 2010 7:22 pm
by mrs.c
lkc wrote:I think this should work...I ungrouped it and all the balls show up in scal...hope mrs c. doesn't mind.
bbac_mrsc.svg
Nope, not at all, thank you. I didn't see this till just now or I would have tried to fix it, sorry about that...inkscape and I aren't the best of friends, but we try to make it work ;)
Posted: Thu May 13, 2010 4:22 am
by gmapatty
I just want to thank both of you for your help. mrsc. I know what you mean about you and inkscape not being the best of friends. Still trying to leanr it and SCAL. Once again, thank you so much.
