Baseball Cupcake Wrapper
Does anyone know where I can find a cupcake wrapper for baseball? And also does anyone know the dimensions of a cupcake wrapper (height and width, etc.)
Re: Baseball Cupcake Wrapper
I made this one, I hope you can use it. As for the size I really think it depends on the size of your cupcakes and the pan you use, I would do a test cut and then go from there. HTH!
- Baseball Cupcake Wrapper AC.scut2
- (101.9 KiB) Downloaded 164 times
- BaseballCupcake Holder.jpg (24.98 KiB) Viewed 2680 times
Thank you , that would be perfect except that I have not made the plunge and pruchased SCAL2 yet. I am still getting used to SCAL. I would not be able to open your file, it has to be an svg for right now.
Thank you
Thank you
Here is the svg version, it is a little different though, but I still hope you can use it!
- BBAC.svg
- (26.89 KiB) Downloaded 135 times
This is really cute - you were so quick to respond to the request posted I am sure she will love it....
Good job
wvcathy
Good job
wvcathy
Thank you for your help. When I open the file in Inkscape it is fine. But when I open in SCAL, it is separated and I cannot get it to go together. The baseball (only one) is separated. Any ideas??
I think this should work...I ungrouped it and all the balls show up in scal...hope mrs c. doesn't mind.
lkc wrote:I think this should work...I ungrouped it and all the balls show up in scal...hope mrs c. doesn't mind.
Nope, not at all, thank you. I didn't see this till just now or I would have tried to fix it, sorry about that...inkscape and I aren't the best of friends, but we try to make it work
I just want to thank both of you for your help. mrsc. I know what you mean about you and inkscape not being the best of friends. Still trying to leanr it and SCAL. Once again, thank you so much.
