Genie Lamp
Genie Lamp
I need a Genie Lamo in svg format. Aladdin's lamp will work also. Need it quickly for a school project for my grandson. Thanking you in advance.
Re: Genie Lamp
There is one here, but you will either need to use blackout, or break it apart and clean it up for cutting. http://www.clker.com/clipart-2968.html
Re: Genie Lamp
I found the same one, but I do not know how to convert it to an SVG. I have attached the jpg. Can anyone help?
- aladin_lamp_clip_art_22867[1].jpg (35.6 KiB) Viewed 2008 times
Re: Genie Lamp
It is available as an svg. Just right click on where it says SVG under the image on Clker and select "Save target as" or "Save link as". HTH
Re: Genie Lamp
Thank you Heather, but that did not work. I found this other image but I do not know how to convert from jpg to svg with Inkscape. Can anyone instruct me on how to do this?
- aladdin5.jpg (10.41 KiB) Viewed 1978 times
Re: Genie Lamp
see your other post, I have converted it for you.
