I need fleur de lis...
Janiselaine
Post by Janiselaine »
I need someone to help me with a fleur de lis. BUT i want and need it to be pieced in four 12X12 matts... so when I cut it out and put it togather its one big fluer de lis... can anyone help me with this?
Re: I need fleur de lis...
There is one at this link here that is already converted.. You can just use the break apart feature in SCAL or inkscape.http://en.wikipedia.org/wiki/File:Fleur ... utline.svg
Janiselaine
I need the shape to be cut into four large 12x12 pieces... I dont know how to enlarge it to make it cut into four
lkc
Post by lkc »
(Using Scal 1)Well, when I make something larger I select the Keep Proportions button, then enter height dimension...for this I put in 23" and the width shows at 23.843...once I'm content with the size I saved the project to preserve it in case scal gets screwy, then for each section you need to adjust your x/y coordinates. The lower right portion shows an x/y coordinate of x -12.000 y- -11.500.
You can nudge it or use your arrow buttons to shift it a little if needed...hope that makes sense and helps.
Laura
Janiselaine
Can you let me know where you got that particular fleur de lis... I love it... it's perfect
