SWIRL or CURL
MotherGoose09
SWIRL or CURL
Post by MotherGoose09 »
I am looking for just the curl part of the lower case "i" in the "Curlz" font. I can't separate the two. Can anyone help???????? I'm tired and don't know how!
Re: SWIRL or CURL
Here you go. :D You can also do this very easily in SCAL2. Type the "i" in Curlz MT, then place a shape over the curl so that the curl is completely inside the shape and the shape doesn't touch the bottom of the i. Select both the letter and the shape, then Path/Intersection.
curl.svg
(3.86 KiB) Downloaded 132 times
MotherGoose09
Re: SWIRL or CURL
Thank you so much! I knew there had to be a way... but I had NO IDEA how! Thanks for the file and the info!!!
AnointedHands
Re: SWIRL or CURL
Post by AnointedHands »
You can also type the letter, select the letter, go to Object>Break Apart and the two parts can be selected separately.
Althea
