How do I? outline letters.
I am making my Boyfriend letters 13 for his race car... I want them in a solid color... and outlined with another... I can't figure out how to make the outline.... can anyone help me?
Re: How do I? outline letters.
If you are using inkscape just duplicate your number 1 and number 3 and then use path/outset..
If you are using scal2 use the shadow feature ...by duplicating your numbers once again and then do the duplicate numbers in the shadowed option... if you notice there is a number beside the shadow.. set it to either 2 or 3... depending on how thick you want the outlined color.. Then cut out your sets in 2 different colors.. if you want yellow and blue.. then do the smaller numbers in blue and larger numbers in yellow.. and center your smaller numbers in the larger numbers...
ok but I want a outline thats line not filled.... with a little space between the main filled number
Just make two shadows then. In the photo below I typed the number 13 (red layer), copied it and pasted it twice and adjusted the shadow. Group your shadow layers together if you want them to cut as a thin line.
- shadows.jpg (33.14 KiB) Viewed 5315 times
If you are doing this in Vinyl, check out this topic. On the fourth posting, there is a You Tube video about doing a two color vinyl. You might want to watch this. This does work as I have done it myself. This way you can line up your outline before you stick the vinyl on the car.
http://forums.surecutsalot.com/viewtopi ... olor+vinyl
It's so funny you posted this Todd as upon waking this am and getting breakfast ready I though about that youtube video and was coming back to post it..LOL.. Thanks for doing this..
If I'm not mistaken at what I think you want, you can find the directions in a reply HeatherM gave to me a good while back. While I was trying to go around a word, You could go around a letter the same way. http://forums.surecutsalot.com/viewtopi ... =14&t=7982 You'll have to scroll down to see her answer to my question and you have to ignore that this thread is about polka dot fonts.
I just CAN'T figure it out! It worked for a second... I saved it and then went back and its not working.... Urrggghhh im just frustrated!
