alligator "Chomp"
alligator "Chomp"
Does anyone have or can make me something that looks like an alligator took a bite off the side of the paper? I need it for a "Honey Do" shower invitation where the groom to be has gotten a state record alligator. It could be where the entire area of the paper is gone with teeth marks in the paper edge or it could be where just the teeth mark cuts through the paper and the inside of the bite stays intact. Does that make any sense at all??? Thanks for your help in advance!
Re: alligator "Chomp"
I don't have a file with a paper with gator teeth marks on it, but I do have this gator file that Joanne uploaded and I altered using Inkscape.
Not sure if it would work for your project, but maybe you could put the gator in the lower corner and cut a slit in the mouth and put your paper inside it's mouth so that it looks like he is holding the paper in his teeth.
- Capture.JPG (36.54 KiB) Viewed 1068 times
- gator2 rev.svg
- (20.51 KiB) Downloaded 87 times
Thanks, Deloris! I'm downloading it right now!
