Butterfly1
Butterfly1
A butterfly. It has alot of cut outs, so I would recommend making it big. I cut it at 4 inches in height and the holes in the wings are still a little difficult to work with, so maybe 6 inches or so would be best. TFL.
- Butterfly2.svg
- (3.67 KiB) Downloaded 489 times
- Butterfly1.jpg (116.49 KiB) Viewed 3849 times
Re: Butterfly1
Nice! Thank you! I am amassing a huge file of butterflies. They look so nice on cards. If I have a design that has small holes, I take it into Inkscape and enlarge the holes so they will show up. It usually works pretty well and doesn't change the design.
Re: Butterfly1
That's a great idea - hadn't thought of that. Now, if only I wasn't so dreadfully afraid of Inkscape. LOL.
Re: Butterfly1
My first post...go me! Like Linda, I use Inkscape to make the small areas bigger. If you can break the paths apart, you can change the size of each piece individually. Once you do it, it is easy. Especially when you use shortcut keys. I use the same method to make my shadow backgrounds.
Re: Butterfly1
Congrats on your first post! I look forward to hearing more from you.
Maria
Maria
Re: Butterfly1
Don't be afraid of inkscape anymore... Just break it apart in scal
you can make some of the tiny ones bigger, and even delet some of them if you want...
from The Wizard of Oz
