2 questions...using SCAL3 Pro
frizz6907
Re: 2 questions...using SCAL3 Pro
Post by frizz6907 »
How do I make it cut the pattern?
HMMMM, most likely you can't, you will have to do print2cut. Add a shadow layer, designate the pattern words to print to cut print, then put the paper on the mat and cut the shadow around is the short version. I'll play with it a bit and see if I can come up with something else…..unless you figure it out first of course :D
frizz6907
Post by frizz6907 »
This is actually going to be for a tshirt for a customer. So I'm cutting it out of heat transfer vinyl.
A better idea is to print your pattern paper first
Place it physically on the mat
cut out the letters from the paper
Funny how you figure it out as you go, especially if you have someone to talk to.
Now you tell me…..
back to the drawing board!
Here, in a nutshell, is how I'd do it for a transfer for t-shirt.
Screen Shot 2014-05-31 at 11.00.27 AM.png (151.44 KiB) Viewed 4325 times
newbiecat
Post by newbiecat »
For cutting do you want the outline of the letters to cut or cut the whole thing into pieces - like paper piercing >
If you want it all to cut then you will need to ensure all the lines are paths - not images !
Pandora
ooops my bad, brain didn't register the VINYL part.
I'll leave the rest to you and Pandora!
Do let us know/see the final project OK?
frizz6907
Post by frizz6907 »
Thanks for all your help, Susan!
Pandora--I don't care either way on the outline. At this point I just want it to work! Lol
newbiecat
Post by newbiecat »
frizz6907 wrote:Thanks for all your help, Susan!
so have a look at the attached file - it is an svg - I have taken your letters and because I wasn't sure what you wanted there are four bits on the page
You will probably need to delete the light blue image - since most cutters don't like images on a page.
Stu.svg
(86.77 KiB) Downloaded 175 times
the black is just one path to cut or not with - the other two I cut in half in case that is what you wanted to do....
Whatever you are putting on the t-shirt you will need to reverse (flip horizontal) to make sure it reads correctly
this will cut exactly as you see the lines - I have taken off the fill and just left a stroke in place - suggest you cut it from copy paper first and see if you like how it is - you can always edit the nodes to remove some of the smaller pieces and weeding it will be fun - or not depending on how you like it - that is also where having it cut from paper helps me since I can see which parts I want to leave in
Do post a picture when you get it done - I have been working flat out for a while and not had time to play lately
good luck
Pandora
