I imported your second post, I believe it was saved as an svg even though you couldn't see it. Then I did the make bitmap copy then followed all the other steps for tracing bitmap and so on. I'm sure there is someone here that can explain MUCH better than me, I only butted in on this conversation early so I could try to learn. Usually when I try something like this I don't post but I was shocked at myself for figuring it out.DHNewbie wrote:OH MY GOSH. That' EXACTLY what I needed.
Can you be more specific about the steps you took? Did you import the original tiff file?
THanks!
Desperately seeking simple cornstalk
Re: Desperately seeking simple cornstalk
I have attached a svg file that you should be able to import and cut in SCAL.
Any problem with the file, PM me.
Althea
Althea
- cornstalk.svg
- (10.72 KiB) Downloaded 160 times
I GOT IT!!! It was the "trace bitmap" step that I hadn't done. I am extremely indebted for your help -- now I have visions of all sorts of new drawings I can scan & cut.
Thank you!!
Thank you!!
Thanks to all for the help.
Now that is a cornstalk that can actually be CUT without a bunch of small pieces. Great job lovebeingamom!lovebeingamom wrote:I was just playing so I could learn...what I did was imported your file, then under edit did make a bitmap copy, then I was able to do all the other steps, and it seems to have worked for me.
Congrats
