Is anyone using these 2 together yet? I have been searching high and low and cant find a thing on it. I just got a Silhouette SD and I did get it to cut with SCAL3 but the grid lines on the mat on the screen does not line up with the grid lines on the actual mat and I am having trouble with inner circles cutting with sharp edges. Like on a doily. The outside scallop cuts smooth but the inner circles cut like squares or octagons.
Anyways if anyone happens to be using this and having good luck could you pass some luck my way? Or at least a little info lol.
I contacted Craftedge support earlier today but no reply back so I thought I would try here while I wait.
Thanks for your time!
*huggles*
Felicia =0)
SCAL3 and Silhouette SD - Question =0)
- You can see in the photo that its not cutting the inner parts round. They do cut round when I use my cricut so I know the files are good.
- P1110832.jpg (205.06 KiB) Viewed 1475 times
Re: SCAL3 and Silhouette SD - Question =0)
I am pretty sure it is on the blog spot of ...under a cherry tree the instructions for calibrating the two together my puter is acting up right this minute so i can't get the link for you she is using MTC in her tut but i am willing to be it is the same for Scal
Scrappin My Way Through
Thank you so much for your reply. I will sure check it out!Butterfly wrote:I am pretty sure it is on the blog spot of ...under a cherry tree the instructions for calibrating the two together my puter is acting up right this minute so i can't get the link for you she is using MTC in her tut but i am willing to be it is the same for Scal
*huggles*
Felicia =0)
Just letting everyone know I figured out the alignment problem! LOL Learning! I am learning! LOL And I got hold of customer service with the other stuff. Will let you know what I hear =0)Felicia wrote:Is anyone using these 2 together yet? I have been searching high and low and cant find a thing on it. I just got a Silhouette SD and I did get it to cut with SCAL3 but the grid lines on the mat on the screen does not line up with the grid lines on the actual mat and I am having trouble with inner circles cutting with sharp edges. Like on a doily. The outside scallop cuts smooth but the inner circles cut like squares or octagons.
Felicia =0)
