I have this graduation file that I want to put on a tumbler. . .but in order for it to go on straight it has to be curved slightly. It is a solid line of grads standing in a row celebrating their graduation. I don't see where there is a feature in SCAL where I can curve the image slightly...is there? If so can someone explain how it works?
I asked over at smartbuygal.com and Treva offered her Make the Cut File for me to use. I guess in MTC there is a feature that curves an image just a bit. The only problem with this is. . .I have SCAL. Is there a way to convert this to an .svg to cut in SCAL?
Thanks for any info!
Katie
MTC file. . .can this be converted?
Re: MTC file. . .can this be converted?
If she sends it in a jpeg format you can just convert it to SCAL.. Do a trace image
Yep. MTC can export files as svgs to import and cut in SCAL.
Thanks for the help everyone!
I have the .jpeg...I tried to trace it in SCAL as well as in inkscape. But its really broken up. The outline of the image is there but it is in dashed lines. Can anyone tell me how to fix this?
I tried to attach the file here but it is too big.
Thanks for any help!
Katie
Katie
edit...
- grad.svg
- Will this work? ;)
- (237.94 KiB) Downloaded 247 times
OK...thanks for sticking with me everyone!
I deleted some of the extras in the file (grad hats and diplomas) and it let me attach it here.
This is what I am trying to make into a nice solid cut...it just has sort of dashed lines throughout.
Thanks again
Katie
Thanks again
Katie
This is PERFECT!!! Thank you!missiethegal wrote:edit...
Disregard my last post please...I didn't see you had posted this untill after I changed the file a bit
Thanks again everyone!
Kate
I think we posted at the same timeKatieK wrote:This is PERFECT!!! Thank you!missiethegal wrote:edit...
Kate
Let me know if you ever need anything else!
