Removing line in Inkscape?
craftymidwife
Post by craftymidwife »
I'm trying to remove the bottom line of an image to weld it to a page border. Is there a way this is easily done in Inkscape?
Re: Removing line in Inkscape?
As long as it's an svg yes you can.. If you look on your tool bar going down the left side of inkscape click on the nodes button.. Then on the bottom of your image hold your shift button and click on the end not on the piece you want removed and the node on the right.. then go to break apart and delete that piece.. If you have a hard time with my explanation you can go to youtube and search for Scrappydew videos..
