Converting....
Converting....
Can this be converted to an .eps file and can anyone do it????
- Contact:
Re: Converting....
There is nothing attached. Do you have an EPS file that you want converted to svg? There is an online converter that will convert EPS to PDF. http://convert.neevia.com/pdfconvert/ You can then either open the PDF in Inkscape and save as svg or import the pdf directly in SCAL2.
Re: Converting....
Thanks so much.. that is a great site!
However, I can't get it to work...
Re: Converting....
PLEASE???? SOMEONE????
Re: Converting....
I tried to convert if using INK but not sure of the results since I have no software to open .eps files. There were some options when I tried saving and I had no idea what to choose so I just accepted the default. Had to upload as zip since this site does not accept .eps files.
Hope this works for you. Any problems, PM me.
Althea
Althea
- Angel.zip
- (82.2 KiB) Downloaded 164 times
Re: Converting....
I converted to and eps in photoshop but it won't open in inkscape..
Re: Converting....
I still can't get it to cut. Oh well... thanks anyway!
