Can someone help convert this into an .svg? :)
If anyone could convert this for me it would be sooo appreciated!!! Thank you!!!
- peterson.jpg (39.66 KiB) Viewed 2620 times
Re: Can someone help convert this into an .svg? :)
Here is one for you. I substituted a font that was close for the name, it didn't trace well at all at that low resolution. HTH
- Peterson panthers.svg
- (25.33 KiB) Downloaded 235 times
You sure are good, Heather! I tried and tried and could not get those gaps closed right...
Good going...you did GREAT!
With an image like that where the part that you want is a gray, reduce the trace threshold until you get the best result. I think I reduced it to 0.35 in Inkscape.
Thanks...I will try again. Night :)
I did it!!!! YEAH...so easy and it looks just like YOURS!! :)
You guys are amazing!! Thank you!!
