Hi!
Does anyone have a file for cutting rosettes similar to the Tim Holtz cutting dies.
Went on to http://paperandflowers.blogspot.com via search on this forum but unfortunately download time now expired and these would have been perfect.
Any help gratefully received.
maureenmcn
Rosettes
- Location: Devon, UK; Windows 7 64 bit; SCAL2 and 3; Inkscape; Cricut Expression; Silhouette Cameo
Rosettes
Maureen
Re: Rosettes
Hi, I made a file, did a test cut. Was not sure if you were wanting a file with embossed lines, so no embossed lines in this file. I had to hand score on my Martha Stewart Scoreboard on the 1/4 mark, turning paper strip over after each score. Attaching a link to a video I watched on how to do this.
http://www.youtube.com/watch?v=jURKWvL1 ... re=related
You can auto fill this file and get 4 on a 12x12 sheet. If this is not what you were looking for, hope someone else can help.
- rosette.svg
- (5.22 KiB) Downloaded 134 times
- rosette.scut2
- (61.78 KiB) Downloaded 103 times
Re: Rosettes
Thanks hellieOh
This is a help (can only download the svg as my broadband connection soooo slow) but I was really looking for ones that have score lines which I can emboss on the Cricut or lightly perforated as in Tim Holtz die. I do not have a MS Scoreboard and need to make quite a few so bit time consuming marking up lines and trying to score them on Eazi Score board. May try and adapt your file but if anyone has a SVG file with the score lines I would be most grateful.
Many thanks
maureenmcn (UK)
Many thanks
maureenmcn (UK)
Maureen
