Black Rose Charms - Alpha and Numbers Updated
AnointedHands
Post by AnointedHands »
Separate files in the .scut file so you can delete any letters you don't need to cut. Just be sure you don't save over the original file if you create a file you want to keep.
Have reposted as a .zip file. You have to save the file in order to use it. If you click on open, you will not see anything in the file. You need to extract it, put it in a directory, then open in SCAL.
Numbers in post below.
Black Rose Alpha Charms 0509.zip
(54.09 KiB) Downloaded 497 times
Last edited by AnointedHands on Sun May 18, 2008 5:22 pm, edited 2 times in total.
AnointedHands
Re: Black Rose Charms - Alpha and Numbers
Numbers file here.
Black Rose Number Charms.scut
(76.99 KiB) Downloaded 285 times
LehighGal
Post by LehighGal »
Wow these a really cool TFS
AnointedHands
Re: Black Rose Charms - Alpha and Numbers Updated
Have reposted with the alphas in one file...should be easier to make words.
