Hi everyone! I am looking for a svg bookmark file. I just purchased Papertrey Ink's "All Booked Up" stamp set and want to find a svg version of a bookmark. I've searched this site and found a corner bookmark, but cannot find what I'm looking for! Here is an example of what I'd like: http://nicholeheady.typepad.com/.a/6a00 ... 7b4970c-pi
It doesn't have to be just like that, just a basic bookmark would be fine, but I'd rather have an svg file for my cricut than to have to buy this die cut.
Any help on where to look?
Thanks!
Bookmark File
Re: Bookmark File
There are alot of tags here on the forum
http://forums.surecutsalot.com/viewforum.php?f=13
When you get your tag into SCAL uncheck the Keep Proportions box and that will let you slim them down a bit. You can have a wider variety. Some of them may not work well that way but alot of them will.
Scrappin My Way Through
Re: Bookmark File
There are tags right in the shapes in SCAL2 also.. Just do like butterfly stated and uncheck the proportions box and make it longer....
Re: Bookmark File
If you weld a rectangle or rounded rectangle to the bottom of one of these existing tags it will lengthen them without distorting the curves at the top. If you are handy with node editing you can do it that way, too. Just select only the nodes at the bottom and drag them straight down together so that only the 2 long sides lengthen, but everything else stays the same.
Re: Bookmark File
I went ahead and checked myself to make sure it was good advice,and it only got a slight bit wonky and yet still very pretty. Thanks to the design of Jennifer Mcquillan, I love that tag.
- book mark.svg
- (13.78 KiB) Downloaded 162 times
Re: Bookmark File
How's this?
- BOOKMARK.svg
- (2.13 KiB) Downloaded 154 times
http://www.cougarrx.com
All my files are for non-profit use only... use them, share them, give them as gifts, but don't sell them
