svg factory
svg factory
What do you suppose this does???http://www.svgfactory.com/index.html
Shirl
Shirl
Re: svg factory
Someone else had a link to this tool as well not long ago. The site says it will convert an image to a .SVG file. The site says to copy an image to the clipboard, then paste it into their tool, then save the pasted image as a .SVG. It's just a file converter, which could be cool to get any image into a vector graffic file. You could then open the file in Inkscape and clean it up as needed, if at all, and import it in SCAL to cut. You might be able to import it in SCAL without using Inkscape if the lines are crisp and you don't want to break it apart.
Re: svg factory
Well a friend of mine downloaded it. She hasn't had the time to check it out yet...I'll let you all know when she tries it!
Shirl
Shirl
