I was wondering if anyone has any tips for helping me make these borders into page edges. I have tried playing around with them in inkscape but I'm not having much luck.
I'd appreciate any help. Thanks!
Need help with this file
- borders, scalloped.svg
- (20.07 KiB) Downloaded 268 times
- Contact:
Re: Need help with this file
Here they are as page borders. To do this, I selected the border, locked it (located at the top), and adjusted the dimension to 11.5" long. Then I created a rectangle. I adjusted this to be 11.5" wide and shorter height wise since I would be adding the border to make it 11.5" tall (just subtract the height of the border from 11.5 to get the height dimension for the rectangle...it doesn't have to be exact). Then you will want to use you alignment tool. Select both the border and the rectangle and center align them on top of eachother. Once everything looks square, select them both and path>union. I check to make sure everything's kosher by view>display mode>outline. If it's all lookin' good, you've done the job! HTH
- borders, scalloped, page.svg.png (35.19 KiB) Viewed 3648 times
Last edited by sensationallychic on Sat Jun 12, 2010 7:19 pm, edited 1 time in total.
- Contact:
Do you mean something like this?
Laura
- Contact:
Oooops...guess I didn't understand what you were needing
...oh well. maybe someone can use this anyway...
Laura
- Contact:
I'm not exactly sure if mine is what she wanted either
I guess this way, she gets exactly what she wanted
- Contact:
And so do the rest of us...bonus!!sensationallychic wrote:I'm not exactly sure if mine is what she wanted eitherI guess this way, she gets exactly what she wanted
I do so little actual scrapbooking but it's fun to play, eh?!...your files look great, as usual!
Laura
Looking great ladies.. Laura I had done the file like yours but then thought. maybe that wasn't what they wanted..LOL.//
I can actually use them both, thanks!!
I've been altering tons of page edges lately- where the middle is not cut out. But recently I've taking a liking to frames so I will be sure to put both to good use!
Thanks again so much y'all!!
