PLEASE HELP ME
StampaLady
PLEASE HELP ME
Post by StampaLady »
I have these SCUT files (gable box #1) that I downloaded from sopranoannie. But when i tried to preview it does not show the correct cut (see #2). When I tried Select All, Group, Path Union, I missing some shapes (#3). Can someone help me, please. I'm having this problem since updating the SCAL2. The SCAL file I think is an SCAL1.
http://forums.surecutsalot.com/viewtopi ... 0&t=7878om
#1 Original
#1 Original
Gable Box-Original.jpg (76.29 KiB) Viewed 2251 times
#2 Preview All
#2 Preview All
Gable Box-Preview All.jpg (32.49 KiB) Viewed 2251 times
#3 Path Union
#3 Path Union
Gable Box-Path Union.jpg (39.96 KiB) Viewed 2251 times
Fida
SCAL User as of 9.15.09
Craigg64
Re: PLEASE HELP ME
Post by Craigg64 »
HI
With cut outs you need to use the Exclude function.
Select the Cut out the Shift select the Background piece that the cut is on and then choose the Exclude function. Once you have done all the cutouts you can select all then use the Union function.
Hope that helps.
If you have trouble I could convert the files for you.
Cheers
Craig
Cheers
Craig
StampaLady
Re: PLEASE HELP ME
Aloha Craig,
Thank you so very much for replying to my post. But I'm so sorry I'm not really good with SCAL. Would you be kind enough to walk me step by step on how I can make this cut file works? If you want, you can email me at jadif@hawaii.rr.com.
Or if you want, if you can also convert the file for me. I want to know the step by step since I have some SCAL1 files that I'm having problem with. Thank you again.
Fida
Fida
Craigg64
Re: PLEASE HELP ME
Post by Craigg64 »
HI
I will email you some instructions.
Hopefully that helps
cheers
Craig
Cheers
Craig
StampaLady
Re: PLEASE HELP ME
Thank you so very much, Craig. It work with the gable box cut file. I was practicing with the other SCAL1 cut files, sometimes it works sometimes not. I think I just needed some practice. Craig, again, thank you so very much for the instructions. :lol:
Fida
