Convert file for SCAL.
gmapatty
Post by gmapatty »
Can anyone help me with this. I have this file that I saved inm Inkscape as an svg file. However whenm I import it mintom SCAL1, I do, not ge the whole picture. So if someone could convert it for me, I would greatly nappreciate it.
Thank you
carrotbox.svg
(6.68 KiB) Downloaded 127 times
pennsylvaniakate
Re: Convert file for SCAL.
Post by pennsylvaniakate »
Here's the outline. I didn't know if you wanted score marks, some people don't like them. The reason it was giving you trouble is because Scal 1 doesn't pick up on dashed lines.
carrot box.svg
(6.41 KiB) Downloaded 116 times
AnointedHands
Post by AnointedHands »
The box as it is here is not going to cut right. I have corrected it but it is for SCAL2 which allows you to cut in layers. With SCAL2, you can cut the outside of the box and then cut the score lines (I turn my blade upside down in the blade holder for score lines), or vice versa.
Using SCAL1, you will have to have the box in two files to cut the outside and the score lines separately.
GrammyKrausse
Post by GrammyKrausse »
In the first svg file for carrot box there are also groups that SCAL 1. doesn't like, Needs ungrouped in Inkscape. And at least one line that is not connected, broken line
gmapatty
Post by gmapatty »
I ungrouped the lines, but I am still having trouble. I drew in a connecting line but still not right. Thank you everyone for your help. Hopefully I can get this resolved. Bed ridden for the weekend due to surgery.
carrotbox.svg
(6.46 KiB) Downloaded 102 times
GrammyKrausse
If you open the box up in Inkscape and color it with any color you can see that the box is white as well as the color you chose. where it is white means there are still lines that are not connected.
gmapatty
Post by gmapatty »
I am not very good with Inkscape, actually have nver used it before today. I am not sure what needs to be done. Sorry for being so dumb on this but it is all new to me.
Rachell
Post by Rachell »
I have fixed the carrot box there was two very tiny pathes not closed. image of the file below scut2 file and the fixed svg. Hope you can still use this.
carrot outline path closed.scut2
(138.08 KiB) Downloaded 130 times
carrot box all outline paths closed.svg
(37.81 KiB) Downloaded 162 times
carrot outline path closed.JPG (49.01 KiB) Viewed 2410 times
gmapatty
Post by gmapatty »
Thank you so much. I will try it and let you know. OK i tired it out and it worked wonderfully. I cannot thank you enough.
gmapatty
Post by gmapatty »
Rachell,
I cannot thank you enough. I was able to cut out the carrot boxes from your file. My granddaughter was so happy. We made 22 of them for her calss.
Thank you again
