Need help
rascalsmom
Need help
Post by rascalsmom »
Hi. I'm new here....loving it so far!! I would like to know how to separate out colors on a picture to cut out the different layers in vinyl. I'm trying to cut out the mascot for my child's school. Any advise would be welcome.
Thanks!!!
Kim
school mascot
school mascot
Carolien
Re: Need help
Post by Carolien »
Hopefully this website will help you http://dan99.blogspot.com/search/label/tutorial.
Good luck,
Carolien
Carolien
Re: Need help
Post by Carolien »
PS You have to scroll down to the 20th January 2009.
Cheers,
Carolien
Re: Need help
I really wouldn't recommend using that method for this image since it will give you stacked traces with a thin black frame on the top of four other colors. You might try modifying this tutorial to trace each color http://dan99.blogspot.com/2009/01/video ... o-svg.html and then use a basic trace to get the black background.
I played with this image last night and wasn't happy with any of the things that I tried in Inkscape. The image is pretty low resolution with a lot of jpeg artifacts. It would be much better if you had a higher res image.
rascalsmom
Re: Need help
Thanks for the info, I had no idea where to even start. Very appreciated. :D I'll try to get a better picture from school too.
Kim
rascalsmom
Re: Need help
Ok, I've tried...even got a better pict., but I can't figure out how to do it. I used inkscape and it will break down the hawk into a bunch of different colored hawks, but not into the individual shapes for the colors. Is what I'm wanting even possible? I don't know...
I'll attach the better hawk if there is anyone who could assist me....many thanks!!! This is for a project for my school's silent auction in a few weeks.
Kim
color hawk.jpg (41.97 KiB) Viewed 3690 times
firstcut
Re: Need help
Post by firstcut »
Here ya go. i used the paint bucket with default settings to do the conversion.
colorhawk.svg
(63.48 KiB) Downloaded 173 times
rascalsmom
Re: Need help
OMG!!! Thanks you, thank you, thank you!!!!! :D :D :D :D :D
How did you do that?
rascalsmom
Re: Need help
Here's the finished product...again thanks for the help.
wvcathy
Re: Need help
Post by wvcathy »
Boy if I made the brown - blue instead - and changed lettering I could use that for our school back home.... if sharing file
Fighting - BlueJays - SHS - Shepherd High School - Michigan
