Lot's of Circles Mesh
- Location: Dartmouth, Nova Scotia Canada Using Scal2, Inkscape .47, Vista
- lots of circle mesh.svg
- (32.9 KiB) Downloaded 797 times
- lots of circle mesh.png (128.04 KiB) Viewed 5937 times
Re: Lot's of Circles Mesh
This is so fun!! Thank you!
I made an embossing out of this...I love it...the pictures do not do it justice...it is awesome!!! The photo is making it look the opposite of how it really looks...what looks debossed is really raised.
how did you emboss with it? That looks like it would come out nice
Very cool looking. Nice job.
Not sure what you used, but I have an easy way to do this here
http://cleversomeday.wordpress.com/2010 ... sy-emboss/
My "How to" in a nutshell, so to speak. I hope the picture tells a thousand words...because I don't have a blog.
I learned this on the various sites out there, though, so it is nothing new.
Use Plumbers Rubber, not sure of the thickness, just a package of two(but only use one!)from HD in plumbing section.
I use deepcut blade on 6 and pressure on high and mulicut 4x.
lotsofcirclemesh done in a single layer. gearsbg cut and then stuck to solid piece of plastic using ATG gun and stuck in the dots with the gun also. With those I only use 2 thin cardboard shims. With the single layer embossing plastic, I use 3 thin cardboard shims. They are not so much cardboard as maybe the covers from a paper stack. Careful not to force to hard and break the CB.
Also, make sure you use the deepcut housing with the deepcut blade also and secure in the holder tight. I do believe this operation may void warranties.
