Need help, please
Need help, please
Can anyone please, please (please?) turn this into a cutable file? I've been trying for 3 days to get it to cut right and just can't. It's for a friend who LOVES corpse bride, and really wants a cut out of this little dog, but I am having major trouble. I guess I need a silhouette of him? I don't know. Help?
Re: Need help, please
Give this a try, I am not that great, maybe this will help.
ProfessorLooney
ProfessorLooney
- Scrapssvg.svg
- (24.69 KiB) Downloaded 325 times
- Contact:
Here's the best I could do.
- scraps.svg
- (30.63 KiB) Downloaded 337 times
Thank you both SO much! Amy, you NAILED it!! Please tell me how you did it!
- Contact:
I found a different pic online to use as the one here was a little out of my league (hard to get a nice trace):D The pic I used had a dark background with a white colored dog. When I traced it in ink, I checked the invert image option and adjusted the threshhold untill I got an image that I thought looked good. After that, I cleaned up a few random nodes and created a shadow for the image by duplicating it and selcting path>outset. Hope my explanation is sufficient!
What program did you use to trace it? If it's Inkscape, what tool is that?
- Contact:
Yes, I used ink. I imported the jpeg and selected path>trace bitmap. Once the trace window was open, I used the brightness cutoff option with the invert image option checked. I did have to adjust the threshold to get a trace that I thought worked. Does this make sense?
I tried that in Ink, but couldn't get rid of the background noise. I used that picture, too. How'd you get rid of all that extra "stuff?"
- Contact:
To the right of the brightness cutoff selection is a place where you can adjust the threshold. Play with it until you get a trace you can work with. After I had one I thought was good enough, I only had to edit a few nodes by hand. HTH
- Contact:
Here is what i came up with, is in 3 layers: gray background, white bones and black for the eyes. Hope you like it.
- CORPSE BRIDE DOG.svg
- (47.89 KiB) Downloaded 298 times
