Help ---Please
Help ---Please
I want to make a vinyl decal for my truck window with my daughters Cheer Squad name and one for my sons Football team name. I have attached a photo of the closest thing that I could find that reflects what I am trying to do. Although, you will note that the words in this photo go all the way around the circle making the bottom words appear upside down. I don't want that - I want ~~~ CHEER at the top of the circle and SHOCK at the bottom of the circle. I also would like to be able to place her name in the center circle (welded as well). I would love some assistance with this - I have the template in inkscape but cannot get the letters to work. I have attached the inkscape file as well. Any help in making this into a easily editable template where I can change the words would be SO greatly appreciated.
- circle_frame_components.svg
- This is the template file
- (4.22 KiB) Downloaded 290 times
- Example - I don't want a picture in the center - I want to insert her name
- Example.jpg (45.08 KiB) Viewed 2642 times
- Contact:
Re: Help ---Please
There is a good video on this here. http://www.youtube.com/watch?v=2f6vVp4I ... 1&index=12
The text stays editable until you convert to path. HTH
- (4.92 KiB) Downloaded 295 times
- Contact:
Re: Help ---Please
Heather, thanks for posting this. I can't view the videos from the heathenx site and I never thought to look for them on youtube.
Re: Help ---Please
Hope you can use this. I made two different fonts.
To add the name, I had no problem when I inserted it inside the circle and welded in SCAL.
Althea
Althea
- CheerII 0216.svg
- (17.04 KiB) Downloaded 159 times
- CheerI 0216.svg
- (24.42 KiB) Downloaded 157 times
Re: Help ---Please
Thank you so very much for your quick responses!! The video really helped and Althea - the two that you had done were wonderful!! I am very new to all of this and I am sure have hours upon hours of learning to do. I had made another one via the video instructions and it worked out perfectly....except for one problem....when I import it to SCAL - the letters are missing! Could you please explain what I have done wrong - or what needs to be done?
My file is attached.
Patty
Patty
- CheerShock Sticker.svg
- (5.86 KiB) Downloaded 290 times
- Contact:
Re: Help ---Please
See your other post http://forums.surecutsalot.com/viewtopi ... =19&t=3760 for the answer and the file.
