It is currently Mon Jan 27, 2020 9:01 am
 Post subject: cutting in same spot
PostPosted: Fri Mar 08, 2019 10:24 am
Hi all,
This happens to me all the time...I mean to cut something with 2 cuts and I accidentally send it with 1 cut and need to send again..but if I take it out of the machine, it won't fall where it should and the cut lines will be different. How can I reset without taking the mat out of the machine?
Thanks for your help!
Laura
 Post subject: Re: cutting in same spot
PostPosted: Sat Mar 09, 2019 6:59 am
What cutter do you own? With some cutters it's almost impossible to achieve this because you cannot reload the mat in the exact same spot thus the origin has changed. That's why I always will lift up a corner of my material to make sure I have a clean cut before I remove the mat from the cutter, in case I need to repeat the cut.
