I have a Problem!!!
Requests for finding a Font or Shape to use in Sure Cuts A Lot
EnriqueP
I have a Problem!!!
Post by EnriqueP »
Good Afternoon, I Have a SB 24 inches and SCAL 4 pro but when I make a cut my silver bullet cut 2 lines on the design CAN YOU HELP ME? :roll:
papasue
Re: I have a Problem!!!
Post by papasue »
If the lines are like slashes across designs it indicates that your scal has not been activated. Is it a new version?, if so then you should have gotten an email from craftedge with a serial code. see http://craftedge.com/support/support.html
If the 2 lines are horizontal lines, then most likely you forgot to lower the pinch wheel levers so that the mat is gripped.
WarnerWed
I have a Problem
Post by WarnerWed »
Are you all set now Nicole? Since you're posting on the forum, you have to be signed in.
