Scan2Cut
karl052
Re: Scan2Cut
Post by karl052 »
Rorysnonna wrote:Hi All,
Do I need to calibrate my laser for assurance chien each time I do a print and cut? I just tried this feature and it worked fantastic. I mostly cut tag shapes over a printed image. This works better than my Brother SnC. So happy you have added the Zing driver to the software.
Hello!
This is my first time here and i just want to say that I’m very happy to be here and to share my opinion.
Thanks!
Eman
Re: Scan2Cut
Post by Eman »
HI
I do have zing orbits and I did all the step for scan2cut excepted I don`t know how to cut and the dots will be my registration mark how,Do I let zing orbit scan the dot or should I use the dot as origin point
please help me it will make big different for me if this work.
Re: Scan2Cut
Scan2Cut doesn't work on the ZingOrbit. If you describe your particular application, perhaps I can provide you an alternative method.
Eman
Re: Scan2Cut
Post by Eman »
Thanks for the replay I do wanna use it for Cutting some of my finished stamp and also my finished stencil. I don't work with the diy cutter because usually I work with big size project
Re: Scan2Cut
One option is to scan your stamp or stencil into your computer first and then use it as a print and cut project whereby you print before coloring. That way the registration marks can be added in advance. Even with my older Zing that does have the ability to use Scan2Cut, I find this process easier plus it gives me the ability to resize the project to whatever I want before printing.
The other option, whereby you can use an already-colored project, was developed using a different software but it should work with SCAL as well. I want to test it first, however, to make sure it works. I will add it to my To Do list and hopefully get it working and documented for you and others. I'll need a few days, however, so that I can get some other things handled first. But it IS on my To Do list now. :)
Jenette
Re: Scan2Cut
Post by Jenette »
I mostly cut tag shapes over a printed image.This
gaso
Re: Scan2Cut
Post by gaso »
Zing driver is awsome!
JackOne
Re: Scan2Cut
Post by JackOne »
Thank you very much for the information! I have been looking for how to solve this problem for a long time
Re: Scan2Cut
You should check out my newest two videos that make Scan2Cut even easier now:
Video 1A Using Scan2Cut on Automatic PNC Cutters (Preprinted Images on Letter or A4 Sheets)
https://vimeo.com/485669801
Video 1B Using Scan2Cut on Manual PNC Cutters (Preprinted Images on Letter or A4 Sheets)
https://vimeo.com/485672858
