help
sophie1979
help
Post by sophie1979 »
Hello everybody,
i would like to add files in my library... is that possible?
I'm on MAC
Re: help
Yes, you can! You'll observe that on the Shapes tab, there is a folder called My Designs. You can add subfolders and load SVG files there. These can also be manually added using Finder on your Mac and placing subfolders of SVG files inside Documents>Craft Edge>My Designs. For your actual projects (.SCUTx files), save those to Documents>Craft Edge>My Projects and they will then show up in the Library under My Projects on the Projects tab or, as with My Designs, you can add subfolders and load SCUT files there.
If you need more help, refer to Section 4.03 in this user manual: http://www.iloveknk.com/0um/ZingOrbit-w ... CAL-UM.pdf
Or feel free to ask more questions here. :)
