Problem with SCAL PRO 4 file with draw and cut lines . . .
mrsefs
Post by mrsefs »
I am trying to create a gift tag in SCAL Pro 4 and send it to my Silver Bullet. The design has both draw and cut lines. It draws fine, then the machine stops, I hit the cutter button again in SCAL, reset the settings to reflect the blade and the V & F numbers and click ok. Then I have to tell the next screen to skip the draw lines. Then it starts to cut. The problem is, the cut is not in the right position. Does this not work, or am I doing something wrong?!
I ended up cutting a simpler shape around the drawn design by hand as I ran out of paper trying to get this to work.
Thanks for any help.
Kathy
mrsefs
Re: Problem with SCAL PRO 4 file with draw and cut lines . .
Post by mrsefs »
Hi,
I just wanted to say I finally figured this out. When sending the design to my cutter I changed the "cut mode" to WYSIWYG and everthing cut as expected! Another note in my cutting reference file for this now happy cutter.
Kathy
