In search of a top note
does anyone here hae a ut for a top note??? the kind found in the cricut storybook cart??? If so I sure would be greatful. TIA
Re: In search of a top note**Resolved***
I found one now I can't figure out how to cut it on the cricut I have the SCAL software and inkscape but can't figure out what i need to do to get it to cut the image any help appreciated
smitten,
Will this help you?
Lysa
Will this help you?
Lysa
- top note.svg
- (4.31 KiB) Downloaded 588 times
Visit with me at http://www.lysaandhueyink.blogspot.com
here it is in scut, Let me know if they work as I didn't cut them yet
Lysa
Lysa
- top note.scut
- (7.24 KiB) Downloaded 446 times
- top note.scut
- (7.24 KiB) Downloaded 320 times
Does anyone know how to create the top note so it has a dotted line on the inside that is just like the Stampin Up Top Note Bigz Die? I created on in INkscape but when I import the svg into SCAL both lines are solid. Help!
Hi,
I don't know if this is what you're looking for, but your question came to mind as I was browsing the web for fonts/dingbats that will allow me to cut box shapes. Go to this link and see if any of these musical fonts can be of use to you:
http://www.scrappingtable.com/catalog/i ... 653060.htm
Good Luck!
Good Luck!
