Need help with converting pic to cutable graphic..
I'm usually pretty good at this but on this one instance I just can't get it right. A friend of mines nephew just got drafted by the St. Louis Cardinals and she wants me to make a mug with his baseball card etched to it. I've tried several times to import and modify and it doesn't look right. The other problem is I"m working off of a baseball card image. I'll attach the cards to this thread. If any one can help I'd be very appreciative. I even tried to isolate just him in the card and still have problems with the converting to a cutable image.
- chris rivera card edites.jpg (12.95 KiB) Viewed 5074 times
- mwDJBbdq10wkASGUaHoGI5Q.jpg (8.32 KiB) Viewed 5074 times
- mQ3K_3bDIP1OAiSQk4_pn_Q.jpg (11.7 KiB) Viewed 5074 times
Re: Need help with converting pic to cutable graphic..
Here is one more image I tried to convert, it's BW
- chris rivera card edites bw.jpg (11.35 KiB) Viewed 5073 times
There isn't enough contrast to get lots of detail. Here is my version. This is just a silhouette.
- Chris.svg
- (17.56 KiB) Downloaded 380 times
Thank you for trying. I also found that an issue where it's just not enough contrast/detail and the image if fairly small. I just thought it was me not able to do it. Thanks again for your help.
