Would someone mind helping me??
prcrstn8r
Post by prcrstn8r »
Hi!! I tried turning this into an svg, but it looks kind of choppy. Can someone please help me turn it into an SVG? PLEASE!!!!
dragonlord666
Re: Would someone mind helping me??
Post by dragonlord666 »
Try this
Pig Logo.svg
(237.87 KiB) Downloaded 408 times
Gaz
Computer:IMac running Mojave
DogCarbon
Location: Amish Country, PA... using SCAL3, Vista, ink 0.46 with my Cameo. Trying to learn alll that I can.
Post by DogCarbon »
here is my try at the svg.
That was fun!
Please use the file for personal use only.
pig.svg
(37.95 KiB) Downloaded 294 times
DogCarbon
Post by DogCarbon »
Gaz,
I see you beat me to it! and because I like to see what others create from the same file... I took a peek at your file.
when I went to move things around to see how the file would work, This is what I got.
That file will not work properly.
There is over 150 grouped objects.
I think you may have used inkscape with the color filters on. The easier way to make the file is to use the paint bucket to get the pig's parts.
I am willing to walk thru with you and the OP on how I created this file!
dragonlord666
actually I use a totally different program to do it. normally works great...... might have to go have a look again.
I do normally use the paintbucket fill in inkscape to trace (I like it better than the trace bitmap) but I will use whatever gets the job done.
something must have gone screwy today LOL
by all means post a tut on how as it may help the OP
Gaz
dragonlord666
it opened fine in Scal3 & inkscape for me
Screen shot 2013-03-12 at 20.35.31.png (259.52 KiB) Viewed 10307 times
Screen shot 2013-03-12 at 20.37.38.png (268.77 KiB) Viewed 10307 times
it's a tad big but I just select all and resize anyway
Gaz
prcrstn8r
Post by prcrstn8r »
WOW!!! Thank You sooooo much everyone!!!! I really appreciate it!! I can't wait to try it out! :D :D :D :D
DogCarbon
Post by DogCarbon »
Even my file as posted won't work well in SCAL because I didn't change the ovals into a path!
I will re-work and re-post, so feel free to download the updated file in the above post.
dragonlord666
of course, it will depend on what you wish to do with the file.
if you want to print & cut it, you would only need an oval around the pic
if you wish to cut in vinyl or paper and layer it then you'd need all the colours as individual "layers" or "collections"
Gaz
prcrstn8r
Post by prcrstn8r »
The Files didn't work for me. One just cut a square and that was it, the other cut the pig and oval outline, and the mouth and nothing else. I am trying to make this for my friend, what they want to do is use it like a stencil, the vinyl is going to stick so I guess they need to paint it on. I hope that make sense. I really appreciate all of you for trying to help me out!!! What else can I do? Any suggestions? THANKS!!!!!!
