Help with text on path
Tips, Tricks and Tutorials for using Inkscape
sue.mn
Post by sue.mn »
Hi
I am trying to do a image of a infinity sign on its side with the work faith within the bottom line. I get the text on the line but I would like it as part of the line. How do I get the text to flow with the line?
TIA Susan
dragonlord666
Re: Help with text on path
Post by dragonlord666 »
you would use the text tool, there are three options and the last one, I think, is text on path. that is what you need to use.
I don't use it much as I design in inkscape and don't do a lot of text on path, but it should work about the same.
you have your shape (path) and your text, select the text with that tool and drag it over the shape. or you can select that tool and then click on the shape and start typing.
hope someone who does use it comes along soon and can help you more.
Gaz
Computer:IMac running Mojave
HeatherM
Post by HeatherM »
After you have put your text on path you can highlight the text and then use the Text property window to adjust the spacing and where the letters are in relationship to the line. If you want the line through the middle of your letters you need to use a negative V Offset. You might need to adjust the spacing also using the Tracking. HTH
text on path settings.png (36.65 KiB) Viewed 12608 times
