I'm having a hard time seeing my design or lettering in SCAL3 because of the mat color. I tried to change it but it there doesn't seem to be that feature. In SCAL2 the mat coloring was perfect for designing and seeing lettering. In SCAL 3 I have to fill in the letters to see them on the mat
Example:
Here is what is says:
If you aren't learning something new everyday you might as well just lie in a grave and wait for death.
I may be totally missing something but here goes anyway.
It appears that you have a very light STROKE on your letters, you could try and make the stroke dark so that the letters show up better without using FILL.
Screen Shot 2013-01-23 at 10.38.08 AM.png (51.58 KiB) Viewed 9215 times
If this is not the answer you seek, try to explain again or perhaps someone smarter than I am will come along and offer another answer
might not help but under preferences, check what your alpha fill is set to under general.
the higher the % number the darker the fill of the shape. Not sure if it works on stroke too
only other way/workaround I can think of is add a cutter that has a lighter mat (try the cougar/lynx or silver bullet) I don't think you need the physical cutter to add it, just to cut to it, so make sure you set it back to your cutter before cutting.
I too would love to be able to change the mat color as with the BC the mat color is orange and with the silver bullet it is blue. I had a friend call and asked the same question can the mat color be changed and sadly I had to tell them no not in scal.
You can at least eliminate some of the lines in between the main grid lines. If you go to view->grid->customize grid you can change the appearance of the lines. I hope this helps a little.
I found a work around where I add a rectangle shape to my design and put it as the color that I would like to have on my background. I then use the "lock" feature and put my design on top of it. I hope this helps!
