Why Won't it Cut??-Ecal
I've been trying to make a chevron print circle and put 3 initials in the middle of it. If I click preview it won't cut the chevron print. Only cuts out a big circle. What can I do to fix this?
- Screen shot 2012-09-08 at 12.07.24 PM.png (27 KiB) Viewed 1865 times
Re: Why Won't it Cut??-Ecal
I think you want to use the Print to Cut feature.
First, put your initials on your mat where you want them (I assume you want them printed right in the circle.)
Use the "Print to Cut" feature. Choose print on the bottom left and make sure it says Draw.
You must print first to your printer.
Then feed the paper in your cutter and set to cut and it should cut out your circle.
These are quick instructions, but I think it is what you are missing.
