ISO a Keeshond
Re: ISO a Keeshond
Yep, it works quite well.
Louise-Paisley
Re: ISO a Keeshond
Post by Louise-Paisley »
Penny Duncan wrote:Yep it sure will........it's a quick way also if you don't have a laser too!!!
the hinge method is quick even if you DO have a laser if you are cutting several..
If you are cutting lots of copies of the same picture it is much quicker to line them up under the cutout sheet than lining the laser on a tiny dot 3 times for every one :D
Penny Duncan
Re: ISO a Keeshond
Post by Penny Duncan »
You don't have to do the laser each time.....just put multiple images on your page.....then when you print will will do the registration marks just once around the entire collection.....so you only align the laser 1 time and it will cut out all the shapes......super super easy!!!!
Louise-Paisley
Re: ISO a Keeshond
of course.. if they fit multiple on a page..
If you are making boxes with printed sides that's not very likely ;)
Penny Duncan
Re: ISO a Keeshond
Yes Loupy I know that....that's a given......
Louise-Paisley
Re: ISO a Keeshond
I made a skip full of party boxes for a Pal, I did those with hinge even though I have laser P&C.
not sure if other cutters have the facility but with the Cougar it was even faster because it is just a case of lining up another printed sheet and press repeat - no need to send the file every time. I love ma cougar :D
Penny Duncan
Re: ISO a Keeshond
I'm there with you on that Loupy......I too love mine!!!!
CricutLuv
Re: ISO a Keeshond
Post by CricutLuv »
Thank all of you so much for your wonderful assistance and time. You are greatly appreciated. :)
Dee
Proud Mom of A U.S. Soldier!!
101st Airborne, Ft. Campbell, KY - Home of the Screaming Eagles!!
